纺织品成分及分析测试相关英语[下]
2012-02-19   发表:
E. Strength tests 强度测试
1. Tensile strength 拉伸
2. Lea strength 绞纱
3. Single thread/yarn strength 单线纱
4. bursting strength 胀破强力
5. Seam performance 接缝
6. Tearing strength 撕裂
7. Bonding strength 粘合强力
8. Loop strength 打结,钩接强力
F. Fabric / garment performance and flammability tests 品质及燃烧测试
1. Abrasion ressistance 耐磨性
2. Pilling ressistance 抗毛性
3. Snagging ressistance 防钩丝
4. Wrinkle/crease recovery 皱纹/折痕回复性
5. Stiffness 布料硬挺度
6. Stretch and recovery 伸展及回复性
7. Water repellency 防水性
8. Oil repellency防油性
9. Soil release 防污
10. Needle cutting 烧针现象
11. Flammabillity 燃烧性
12. Surfce flammabillity of carpets and rugs 地毯燃烧测试
13. Durability of applied designs and finishes to dry cleaning 印花花纹和整理剂
14. Wettability 湿润度
15. Absorbency of bleached textiles 漂白纺织品和吸水性
16. Air permeability 透气性
17. Water vapour permeability index 透湿指数
18. Thermal stability of coated fabric 涂层织物之耐热性
19. Resistance to blocking 抗阻塞性
20. Water vapour transmision 透湿性
21. Dry fit function 快干综合功能
22. Cold bending test for coated fabric 涂层织物的低温弯曲度测试
23. Brittleness temp. of plastic sheeting 塑料脆化温度
24. Antistatic 防静电
25. Thermal ressistance 保暖度
G. Fibre & Yarn tests 纤维及纱测试
1. Linear dendity 纤维线密度
2. Fibre fineness 纤维细度
3. Fibre diameter 纤维直径
4. Yarn counts 纱线支数
5. Denier counts of filament Yarns 长丝纱纤度
6. Identification of continuous / discontinuous fibre 长丝/短丝 纤维鉴定
7. Twist per unit length 纱线捻度
8. length of thread (per roll) 纱线长度(每轴)
9. Net weight of thread 纱线净重
10. Dimensional stability of yarn to washing 纱线缩水率
11. Single fibre strength 单纤维强度
12. Single thread/yarn strength 纱线强度
13. Lea strength 绞纱强度
14. Loop strength 打结、钩接强度
15. Yarn evenness 纱线均匀度
16. Crimp test 卷曲测试
17. Holes on synthetic fibres 纤维孔数
H. Carpet tests 地毯测试
1. Colour fastness 颜色牢度
2. Thread per unit length of backing 底部纱线密度
3. Weight per unit area 重量
4. Pitches per unit length 毛束经密度
5. Rows per unit length 毛束纬密度
6. Thickness 厚度
7. Surface pile density 表面毛绒密度
8. Ply of pile yarn 毛绒纱股数
9. Fibre composition of pile & back 毛绒及底部的纤维成分
10. Surface flammability of carpers and rugs 地毯燃烧测试
11. Abrasion resistance 耐磨性
12. Pile height 绒高度
